Caporegime
- 1 Mar 2008
It's easier to remember as *#*#INFO#*#*
This doesn't work for me. It just trys to call then fails.
In the call log, I notice it leaves off the first *
Is there any way to test whether the flash works? It doesn't appear to work when I set it to go off when using the camera but I want to double check it before I take it back. There is a flashlight app which doesn't work as my phone isn't rooted.
So my flash doesn't work at allGet "LED Desire Light" from the market, doesn't need root (nor do most of the other flashlight apps)
Khaaan! (and others)
Is the trackpad meant to light up, or not?
Last thing I'm confused about (bearing in mind I had a Hero ages ago).
You can only wake the phone via the power button, that right? (Google suggests that is correct but I'd rather ask here too)![]()
Has anyone rooted and used a Nexus One ROM? I would like to go to FroYo without waiting however long HTC are going to take!
Anyone with the desire on tmobile, how do you find the 3gb cap on data? Do you have to be really careful of youtube and other streaming when out and about and turn off all syncing etc?
