*** The Official HTC Desire (Bravo) Thread! ***
I thought as much. Perhaps better to go through Carphone Warehouse then and get a unbranded/sim free handset, I think they are anyway.
Anyone know if the benefits are the same? as on the orange site I'm looking at Panther 35, that comes with 400 mins, unlimited texts, internet and 50 picture messages a month (18 months). Will these same things be on the contract if I buy via carphone warehouse?
Probably an idiotic question but thanks if anyone can answer :)
They might not do the same price plans. Check their site and see if they offer anything similar. I think CPW Orange handsets are branded, I think that's where Khaan got 1 of his.
Mine is from CPW and is 'Orange'. But it's SIM free and completely unbranded. They'll get one out for you to show you if you ask them.
tried estrong, wont stream video from my file server. See all my data fine with it, but as i access the video, refuses to play without transfering the whole file to my phone itself b4 playing ????
I got my Samsung i8510 from them last year. Hassle free as long as you remember to cancel the tech support that's free for the first month, but costs you £5+ p/m after that.
You could try MobilePhonesDirect, as the Desire is free on T-Mobile / 18month@£25 / 300min&text / unlimited internet. Same deal with Mobiles.co.uk costs £70 for the handset.
Advantage is Mobiles.co.uk have them in stock, whereas MPD aren't getting more until tomorrow at the earliest apparently.
Just spotted a good deal at Mobiles.co.uk.
Thanks for the heads up :) Can save loads of money be not going direct to Orange.
Decided to finaly give my desire a full test run tonight (although the internet is down) i have the following car cradle
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350344927919&ssPageName=ADME:B:EOIBSA:GB:1123
which i got from this thread somewhere, just noticed you cant really plus the power in whilst in the cradle, will go in but i think after some use it'll just screw up the connection. I am thinking about hacking a hunk out of the buttom so it doesnt cover the micro usb port. Anyone else done this? or any other mads they've done to get around this.
I have the same car holder, I don't think mine covers the connectors..
Hi all
I'm hoping for some help here i've just got my Desire today didn't look at it till tonight as i was at work till 9pm.
I've got a few problems i'm hoping someone might no the answer too.
First off i imported all my contacts from the sim card but now i see sim card contacts and phone contacts?
My other issue regarding this is that on my old phone ( sony w980i) i could hold a list of numbers for one contact so for my wife i would have
Mobile number
work number
Private number
Now on the desire it's only showing one number here work number, this is the case for a few of my contacts , Any ideas ?
Wifi issue
It's found our home wifi but every time i put the key(password) in it keeps saying wrong password? even though it's correct , Does it matter if caps are off as my password is all in caps?
If your passkey is all caps then...you need caps on :p
Once contacts are moved/copied to the phone it will sync with your gmail account. Go into Gmail and then manage all contacts there. Set them up perfectly then give it a few mins and they will sync correctly back to the phone.
From here on you can manage contacts from either gmail or phone and assign people to groups and whatnot plus add more numbers and details and so on.
To delete sim contacts quickly just put the sim into another phone and wipe them off.
I have this problem and all i do is just delete the phone contacts so it just shows sim....
1-Go into your contact, press menu then edit contact and next to the number you already have for the person there is a green plus, press that and it will add a new number which you can customize. (Copied from Skyfall in another thread)
2-Yes put in your password exactly as it is eg if yours is TERRY and you put terry it wont work ;)
EDIT:Argh beaten!! :p
Question!
I've seen the Google Navigation car dock screen (the black arch thing with the buttons on it), how do you get that to appear, do you need to install it, if so, where can I find it?
I'm sure I saw Khaaan! link it but I'm at a loss to locate it and google isn't helping :p
DOH i'm so stupid with the password not in caps yep i have that working now.
I've sync gmail but i can't find anywhere on there where my phone contacts are?
Log into your gmail from a web browser on the PC?
The curved cardock panel is for stock Android, HTC Navipanel is out though, link posted a while back!
Yeah thats what i've done all i have is 13 contacts ( emails) from peopel on the web i know.
Nothing at all on my phone contacts.
I've worked out switching all the sim contacts off in view but i only have one phone number per person which is annoying me at the moment!
Ah sounds like you've imported the contacts to the phone memory not the phones google memory, there's 3, sim, phone and google.
Import them to Google contacts.
Go into the contact, at the bottom click add detail. You can add other numbers, emails etc from there. :)
