People who received a non branded Desire (Vanilla) don't need to use a goldcard to root. So if it came in a white HTC box then you're good to go.
Mine came in a white HTC box but has O2 branding on the bootup screen.
Well, I'll have to see later on!
If I register an account you can just tell me what you want on it and I'll make you a "bake", it's no problem
I assume the default Launcher when you disable Sense, is exactly the same as the N1 Launcher, correct?
That's correct but I'd hold off the kitchen until there's more confirmation that excluding Sense is all fine because it seems you have to leave enabled the stock apps like friend stream, peep and sync etc.
I feel a sense of freedom when I think about jumping to a HTC Desire.
Probably me but I want o make sure I do it right lol!
Slightly different to on the HTC Magic when I did that back in the day!
Just got my Desire
Is there anything I "really" must do ?
Well considering it looks as simple as sticking a zip on the SD card and then pressing a button when you turn the phone on, and loading the new "update", I cant see you spaffing it up, but I'll let you go first all the same![]()
