Fitted it but it's not as loud as I thought it would be, really pathetic this is the legal limit. Then again the holes where ( I think) most of the sound comes from are pointing to the back rather than the front, I guess I'll try rotating it within the next couple of weeks. Using the stock cabling not using the relay. Fitted it in the same place the stock horn was.
It does sound far more mature though.
