You must see smooth different to me as his roms lag slightly in live wallapapers as they all do.
Well, its not quite perfectly smooth and it varies depending on what your phone is doing but its certainly a step up from the default ROM speed.
That WinFF program that Kreeee suggested has been great. Just converted a few movies I recorded on my PS3 and popped them on.
Ferris Bueller
Naked Gun
Groundhog Day
Something to do with the videos not being allowed to play on mobile devices I think, not an android issue just a mobile one.
take it back?
****! I swore I would never get another branded phone after getting a T-Mobile G2. Yet I jumped in and got the Desire on Orange, and to be fair, the branding is 10x worse than my last phone being called a G2 being apart from the rename, there was nothing different to a normal Hero (software wise.) It's shocking that Orange saw fit to replace Gtalk with 'messenger' and there is no way to get gtalk enabled other than debranding, and to debrand, we have to create a gold card, and it seems from reading some forum entries, that a there is a risk of bricking it.
Is it actually possible to brick the desire beyond repair?
BTW. Sorry for the rant. I dug my own whole,![]()
The stock desire ROM is horrible for battery use. With a few apps you can easily get 2-3 days use from it.
Biggest drain on the battery is mobile data/wifi. Disable it when your not using it! Juice Defender is a great app, that can double or triple the life of your battery, if your phone is rooted get SetCPU, that be used to control the CPU speed on the phone. Instead of 1Ghz all the time, it can down clock the CPU to 245MHz extending battery life considerably.
