If you're going to be using Froyo, don't bother with that at all because 2.2 doesn't support EXT partitions.
Doh!
Started already.... No harm done
Provided you have installed a new ROM, it must be, as the bootlogo must be stored in the Bootloader or something.
I still got the HTC Quietly Brilliant thing with Froyo installed
Fastest way to check you are rooted - open the menu and look for Superuser under "S"![]()
Indeed you do, it's as simple as sticking it on the SD card, vol button down to get into the boot menu, run recovery on your PC and wipe then update. Job done. (Just about anyway)![]()
Camera autofocus has been fixed on Froyo, update should be here later today.
I should probably prepare now, right?![]()
Can someone post me a link to a step by step guide on how to root please![]()
I now have a desire and I blame you guys. What should I do with it first? How can I stop it vibrating as I type for a start? Lol
Defrost update 0.5 is out -
Version 0.5: (update only for now, apply after 0.4 full rom)
* Camera Autofocus working (big thanks to deovferreira)
* Audio-mod loudness values lowered (some people reported echo)
One step closer to full Froyo![]()
