A Voodoo 5 5500 was 9.6" so compared to this dual GTX470 it's smallvoodoo5!
 Dual 465 wont be enough to beat the 5970 that really would be a pointless card
To compare the price fairly I would say you would be nuts to pay over £240 for a 5850 and £290 for a 470 (stock versions).
The 470 is significantly more expensive than a 5850
I was about to reccomend the 5850 if your only going for a single card (when OC'd they are only 4-5% slower than an OC'd 5870) - but if your having issues with drivers in ArmA2 then you don't really have much choice. I still find it hard to reccomend a single GTX470 based on the price as well as performance but it will do the job.
Yeh I dunno. The GTX470 is £40 more than a 5850, but the driver support is far superior... probably worth it. My GTX260 is borderline at 1920 x 1200, thats the problem. The GTX260 is awesome, but my res is a little to much for it now.
Would be very interested in this card if they price it right.
Heat won't be an issue as I'll slap it under a waterblock. Power wouldn't be an issue (except the cost but meh) as I will be using a 1.5KW PSU.
once thing i hate about pc`s is that with about an hour the room is getting uncomfortably hot, usually you have a pc in a spare room or bedroom. really wouldnt want 450+W just on the GPU let alone the overclocked 4 or 6 core needed to reduce to bottle neck.
i think ati`s lower tdp and more efficient cheaper design is the future, not the other way round. I can play on a 5850 and not see much rise in temps over my 5 yr old budget nvidia card !
And to think less than a year ago people mocked me for defending having 800W to 1000W psus
And as for prices, we know that even if it came to market, the price would be wrong. Look how silly the gtx465 cards are. If if less than double the price (which it should be) it will be £450+ which is silly. You may as well buy a gtx480.
if your room is getting uncomfortably hot I would advise moving out of the boiler room and get some decent coolers for your PC
