Lube yourself up sunshine... for a bright orange shafting![]()
Every network has a fair usage policy though.
Yes, I'm aware of that. But surely 3GB/20GB is better than 500MB.
I wouldn't worry too much though Bradmax57, you probably won't be going over it, unless you stream music and video much, or use the sat nav loads. (Loading pictures and such)
I thought orange was 750mb anyway
Depends on your tariff!
Double twist media player adds my ringtones as music. Any way to stop this as other media players manage not to...
Mines on Orange, The branding isn't terrible, Orange logo on boot, and a few icons changed, really isn't a lot tbh. Though I've de-branded mine anyway
Consider T-Mobile, same deal and you'll get a bigger data allowance.![]()
Been going through the motions of rooting...
Bit of a problem at my end... got round the error 90 thing etc without issue.
But after running step 2, I get to the recovery menu - but there's no way to alter the selection... only reboot device is selected... I've tried using the volume keys and optical trackball to no avail.... just cannot get the cursor to move at all
I must have tried 4 times now (rebooting phone, going back in to recovery and running step 2 again)
Have also tried the alternate enter-recovery.bat file.... same thing
Any advice?
Cheers!
(posted this on modaco too)
