Actually yeah looking at the additions I'll just install and stick with MCR 3.1 and update as it goes![]()
I'm looking at MCR. I've had my desire 48 hours, and don't like sense.
What I really want to be able to do is use the stock launcher, and get rid of all the htc sense stuff (as old youtube vids showed was possible with really early desires). Is that possible with MCR 3.1?
Yes, you can remove it using the kitchen, but you have to pay![]()
Khaaan, did you have any issues? What OS are you using? When I get to step 2 (as in, step 2 windows.bat) and it asks you to plug the phone back into the usb slot, the phone is never recognised (just says, no device found).
I'm using windows 7 x64 with HTC Sync and the x64 vista drivers.
Just wondered if you'd share any caveats you came across to help you
It's pretty easy chippie, use Modaco's guide r5 like me and you should be fine
Now begins the long night of restoring all my settings and apps!
