*** The Official HTC Desire (Bravo) Thread! ***
You might need to reset it to defaults perhaps? something went wrong during OTA :/
I don't remember if the stock recovery/fastboot menus offer rsetting of the phone (hold back or volume down when powering on) bnut it may be worth a try.
Or reset in the phone itself before it crashes.
Can I still backup and restore?
Not without root. But if MyBackupPro runs without the phone crashing then yes (without root features).
Danger Phoenix, root it and put McR 3.1 on there, see if it still persists, that way you can filter out a hardware fault (or not) :(
Or, if you don't want to risk that incase you need to send it back, try and put another ROM on there via RUU.
I have been tempted to root the phone and install one of the Froyo ROMs but have been a bit hesitant.
What is RUU?
What is RUU?
Rom Update Utility, it's basically a simple program that does everything for you. Tends to be provided by HTC, but has been modified by Modaco in the past etc.
Here are the RUU's for the one you have installed now -
http://forum.xda-developers.com/showthread.php?t=684259
Try and install it again over the top of it, might help you never know, or find and go back to an older one.
I like those screenshots Khaaan, might have to have a dabble. Not bothered about having a hacked 2.2 yet, just would like to try some of the stock stuff to see how it compares to Sense.
Still a bit baffled as to all the comings and goings in here, if someone does write a nice clear guide with pictures, that would be awesome ;)
Tried to install Sparta this morning, 3 downloads and 3 flashes and it kept getting caught in a boot loop, ended up with Bravesoul, apps2sd working and the obligatory 1267mhz OC.
Ditched Sense straight away, still using Launcher Pro with 5 icon rows, and yes, as per the instructions they look gash in landscape.
