*** The Official HTC Desire (Bravo) Thread! ***
Whoa, used the "Gold Card Tool" and it seems to be working...
EDIT: So I need more than one card to do it, as I can't reformat from a GC without going back into my phone?
Arghhhh, after running step1 successfully and realising I'm stuck with one memory card, I'm also now stuck with the bootloader menu?
It won't work with the GC in, but I need somewhere to dump the update, so I need either: somewhere else to wipe the card, or another card?
It's now booted normally, strange...
After looking at some stock images I've noticed that you get more icons on the bottom, whereas on Sense you get the menu, phone and add.
So basically what would I lose by turning HTC Sense off apart from the bottom bar? I currently use the Power Tools widget I think it is, the gaint clock/weather and the calendar.
I think you will be ok if you leave the goldcard in or try without a card in.
Just try step2 like that. What do you mean stuck with the bootloader menu?
I think Jamesbcd used his GC again as a normal SD.
Hmm. Tempted again now. I wasn't going to mess about but nggggg.
I think the reason it failed last time was the error 90 on step one, people say to put a 'sleep 10' before one of the commands in the .bat, might try it.
I did that on Windows 7 x64 and it did the trick straight away.
Right, might have a bash then. I'm applying the rootedupdate.zip that comes with the r5 package even though it's from early May?
What will that wipe on my phone, everything?
My step1-windows.bat file ended up looking like
Code:
@echo off
echo Desire Root Step 1
echo.
echo Erasing cache and rebooting in RUU mode...
echo.
fastboot-windows.exe erase cache
fastboot-windows.exe oem rebootRUU
echo.
echo About to start flash...
fastboot-windows.exe flash zip testimage.zip
sleep 10
echo.
echo Rebooting to bootloader...
echo.
fastboot-windows.exe reboot-bootloader
echo.
echo Step 1 complete - now use the bootloader menu to enter recovery mode.
echo.
echo To do this, press the power button, wait a few seconds, then use the volume keys and power button to select the RECOVERY option.
That let windows 7 run through it fine.
For some reason my mobile internet has stopped working on Orange. Had a look in APN settings and my Orange Internet profile is called orangeinternet_off and things like username and password are blank. Any ideas how this could have happened and how to fix it?
