You using any widgets that cut the APN? It will say _off when you use those.
Think it may have been a bug with SwitchPro Widget. I had to edit the APN and remove the _off.
On a side note, the Sparta ROM has only one wallpaper built in, where do I have to put them to get them to appear in the "Wallpaper gallery" option to change them? What size should they be?
Quickest way would be to go to your google account now and add all the numbers to your google contacts, then when you get the phone put in your google username/password and it will add them all for you![]()
You can select wallpapers from your pics folder on your SD card. Checkout Zedge on the market for Wallpapers and Ringtones. Free and there is some amazing artwork, much better than the defaults.
will it let me cherry pick my contacts as i have loads in gmail i would not want on my 'phone contacts'
Yeah, but was just wondering where their default location was - only one is appearing without having to search my card?
I moved across a 1900x1200 but think that was too big! What size am I going for?
Testing RomManagker which does the whole wiping/flash process for you straight from the app. Just choose the rom and away it goes.
I have my phone default set to Charge on the USB. Everytime I connect the phone it says charge but mounts the SD. If I select Charge again it unmounts the SD. Pretty sure this did not happen with the stock rom. Anyone else having this problem?
I'm running Pays BraveSoul V2.0, only issue I can find. Not major just a pain.
This is excellent. So easy to use. 5 stars.
Out of interest, got DoubleTwist installed? There's an option in that.
