- 3 Oct 2009
- Wales
Today looks like a massive cheat day. Going down t' pub for 12:30 and staying there until the england game finishes. Tut tut.
Pullups BW 4,3,3 These are just as hard to perform as they were months ago. This a really big sticking point for me. I haven't really seen any progression at all.
Thanks for those words of inspiration SkillFingers crossed that the Deadlifts and BoR's have a synergistic effect and improve my lat strength and endurance.
I can't even do 1 convention pull up with the palms facing away. I can only do pullups with the palms facing together or towards me.![]()
11th June
Flat BP :: 62.5kg 4,3,4
Squat :: 95kg 4,5,4
Deadlift :: 100kg 5
I'm gutted that the Squats have stalled. Ok, I COULD have done 5,5,5 and I know I CAN go heavier but the sets arent smooth. I dont recall the Starting Strength book saying anything but to my mind a good set should be executed smoothly with each rep coming out with no pauses and I had pauses on all of my sets. Form still not spot on.
Those are chin ups.
You should try some negatives, get on a bench stand up in the top position and then slowly bring yourself down with control.
That'll give the muscles a workout aswell, got my old training partner to go 0 Pull ups to 10 easily within 2 months.
How long should it take to be able to do more reps. My body isn't even getting past the first stage :/
I have started fairly low (well, at least in regards to what my friends are doing) at 15kg dumbells. Problem is that doing controlled bicep exercises (standard stand firm curl dumbell from waist to shoulderish I don't seem to be making much progress....my body keeps petering out at around 7 before I can't continue (8-9 right arm).
I am also doing a few other exercises including running, doing pressups with boths hands apart and hands together (15-20 at a time)
If I take a break for a minute or so I can then do another 7 odd again.
How can I improve my stamina so I can lift these weights more consistantly?
Is it simply a case of doing more than a few minutes of weights every few days (10-12 minutes on average).
Well how are you going about lifting and what are your eventual goals ?
Could you give a rundown of the lifts/exercises you do every session, then maybe we can see where you're going wrong.
8 reps max is what I'd be aiming for with any isolated exercise ala bicep curl btw
It will usually work out at:
8 bicep curls (Make sure your elbows are tucked into your sides during it. )
small break
pushups with hands together (for biceps??) x15 (If they are together aka diamond push ups, it's for Triceps. In fairness if you have a barbell, do skull crusher and close grip chest presses for triceps.)
pushups with hands apart (for chest?) x10 (It'll do your chest a little bit, but don't expect reall gains.)
8 bicep curls. (Same as above)
This is every couple of days, along with the occasional 2km run.
Not looking for much to be honest, just looking to trim up a years worth of bad eating at university and to gain a bit more definition as well as losing my lanky status![]()
If you want to lose lanky status stop with thinking that you can trim up.
You want to gain mass, so Squat, Deadlift, Pullup/Chinup, Press, Bent over Row and benchpress/dumbbell press.
Those alone will make you gain strength and mass.
I went to a gym once and the instructor basically told me that I could not gain a "thick body" so to speak. He might be right considering my body proportions, so maybe if I simply gain definition along with some mass that would be a compromise? All in all, I simply want to help peoples perception of myself. Lord knows I could do with a confidence boost sometimes
body stats: 6'2(around that, maybe slightly taller), 69kg, so as you can see, not a broad frame
I'll post a picture later so you can see what I mean.
This is true, my dead is only about 10% more than my squat, I'm pretty sure I should be able to dead a lot more, but I'm finding it tough! Guess it might have to do with grip strength?
Are you dropping it? Then it's grip strength, train your grip. If you're not dropping it but your deadlift is low, you just have to work harder on the deadlift. My squat is 50% of my deadlift (50Kg and 100Kg for 4 x 8 respectively).
Considering I have but a set of dumbells and the floor, what routine would you suggest for me?
regards
I feel like a used sanitary towel.
