Bumhug from <Wiped>?!
(Camerlengo - Priesty).![]()
 There is still a Wiped guild on Draenor with a Bumhug the only member, but the original has moved about a bit and had a few name changes along the way
I was never sold on Path of the Titans, as G-Man pointed out there is always going to be a combination that works best and everyone will just go for that. The other problem is what happens with it next expansion, does it continue or just forgot about, plus adds a whole new dimension to balance.
Was probably one of those things that looked good on paper but when people started using it was clear it wouldnt work
My god that was a while agoThere is still a Wiped guild on Draenor with a Bumhug the only member, but the original has moved about a bit and had a few name changes along the way
I don't see it listed anywhere that battle.net is under maintenance for 2 days, especially since other WoW forums are working, as does logging into both the live and alpha clients.
Can't even find a single (obvious) mention of battle.net maintenance anywhere on the live forums no idea what the deal is there >.>
not got any massive hopes of getting into it, been in wow since the start and didn't get into the previous 2 expansion betas, was just curious if anyone knew more.
