Actually, yes I did. I've logged in using both but can't download with either
I had this problem, try switching it back and then try
A couple of days ago, while I was in irc I read a good tip that James_B found. You can change the gmail account that the google apps use without having to do a factory reset on the phone. Just go to: Settings>apps>manage apps and clear the data for “google apps”. This works on Android 1.5
I think you can just add a new group on gmail for the contacts you want to keep synced with the phone?
Thats a forum post not an indication of a known fault.It makes every bit of difference: http://www.google.co.uk/support/forum/p/Android+Market/thread?tid=35ae480b5fa3f9cf&hl=en
I'm not sure if they've made a fix/work around yet.
Erm, trying DeFroST 1.0 and it's not connecting to my WiFi, just continually scanning, and doesn't seem to want to even try the mobile network even though it's enabled.
Use MoDaCo instead, much better ROM![]()
Ah i see what you mean now (I normally go to the contact first to send a test)
And that is pretty annoying actually![]()
Tried that, and there was no Phone or Contacts app.![]()
Ive got mine setup with both and it works fine.
Known issues with changing your address
Android: If you use an Android device and change your address, the following apps may not connect properly: Google Talk and Android Market. The current solution for this is to change back to @googlemail.com, or do a full reset of your Android device and use @gmail.com. We are working on resolving this issue as soon as possible.
Does anyone's Desire make a sound when you get a SMS coming in whilst on the phone? I get a faint beep for incoming calls whilst on a call, but no notification for SMS or Emails![]()
