Thanks
How well does Dr Colorchip work on lighter colours? I swear I've only seen the results on black cars!
Had a chance to use the DAS polisher on my car today and after 5 hours these are the results
Yea it works ok, its just the shipping cost of the stuff.
Yeah, a work colleague wants a kit though too so we're gonna split the shipping cost.. Makes it a bit more bearable!
Can anyone recommend a shampoo to remove wax? The car currently has Dodo juice purple haze applied if it makes a difference?
I would like to make sure I thoroughly strip the wax so I can polish, glaze and then apply new coat of wax.
