Crest whitening strips
Caporegime
20 Oct 2004
Has anyone used these before?
They seem to be get great reviews?
My teeth have a horrible yellowness to them, poor neglect with smoking. I have tried everything over the years to fairly expensive toothpastes and electric toothbrushes. But they still seem to stay the same. These seem to be a relatively cheap way to get the results required.
Something like this;
http://www.biovea.net/(S(ey4oblje2ojxeb5503tv3qrw))/product_detail.aspx?PID=2355&CID=0
Have used the crest advanced seal strips before and they do work well, im not a smoker so not sure if they'll remove those stains, i bought them off the bay for about £25. My teeth did feel a bit funny after about 10 days(14 days worth in packet) but nothing i couldnt handle was just a tingling feeling not sensitivity
will be getting some more soon as you can use them every 6 months if i remember correctly
Let us know how they do mate. I've quit smoking after 17 years (since I was 13), and need to sort my teeth out - I can feel my lungs healing already (after only 2 months!)
Yes, I have.
Specifically the ones I bought were in Canada, a good few years ago now, which was before there were really any at home whitening products being sold in the UK. I'm unsure whether the Crest Premium Whitening Strips are sold the same here, as I've not actually looked into it.
Basically a friend of mine had really nice white teeth and I asked her if she had them whitened; she explained that they were from using the Crest Strips, so she found them in the local Chemists for me.
You basically wear the strips on your teeth for about 30 minutes everyday for a couple of weeks and the results are amazing.
It doesn't last forever though. I'm not a smoker, but I do like coffee. It's been a number of years and my teeth clearly aren't quite as white anymore. I did bring some strips back with me though, so I think I might have to dig them out.
Tempted to press Buy it Now right now.
The cheapest i can find from a reputable seller is £24.99 + 2.95p&p for the CREST WHITESTRIPS PREMIUM TOOTH WHITENING WHITE STRIPS
Are these the right ones?
Or are the Crest 3d Whitestrips better ones?
By looking about its worth the extra couple of quid on the 3D pro ones?
They contain more of the chemical that does it, and only requires 7 days. Not that bothers me too much. If it does work though, I will certainly be doing it every few years.
Was going to buy these ones but i read the reviews and a lot of people say the bottom strip is way too small and doesn't stick.
Crest 3D White Whitestrips Advanced Vivid
Not sure what to do now.
I wouldn't bother with the "3d" ones. I had the regular ones and they work EXTREMELY well. I could see noticeable results after only 5 sessions.
Definately recommended!
OK then, thanks.
Would you be able to tell me the specific ones that you used please as there are so many?
There are :
CREST WHITESTRIPS PREMIUM TEETH WHITENING WHITE STRIPS x28 = £25.99+p&p
or
CREST WHITESTRIPS SUPREME PRO TEETH WHITENING 42 STRIPS = £26.95inc p&p
Are the top ones better? The bottoms ones apparently are dentist professional ones.
Too many choices :(
There are a lot of choices, generally they all seem the same thing though. So don't think it matters too much.
Just had a look on Wikipedia.
Apparently, the two that i listed above were released in 2003 and 2004.
The newest ones previous to the 3D range are the Crest Whitestrips Advanced Seal
They are on ebay for £26.99 for 14 days worth. These are 10% peroxide, so i think i might go for those ones.
