Caporegime
- 13 May 2003
- Warwickshire
Are you on VM already? If so just go for it. Installation fee aside (it's only a one-off after all) the 50 meg package itself is only a couple of quid dearer than 20 meg. Well worth it just to avoid the STM/throttling on lower packages, even if you're only a "casual" user. At least that way you can watch iPlayer and download games without having to plan around several hours of congestion and throttling. Have a think; but you know you want to.![]()
Yep, on 20Mb at the moment. It's £55 up front and an extra £8 per month, which is £151 if written off over the year so not insignificant for someone that, if I'm being honest, only wants it to torrent faster.
@RobbieG - Still no capping and has been no word since launch about when they will introduce it. They wont do self install as the engineer is SUPPOSED to ensure the power levels are correct. The only way to correctly adjust this is by moving you up or down the panel in the cab which means no self install. You can use attenuators your end but trying to get people to do that self install is a bit of a headache and not a plug and play job.
Ok, thanks for that info. I suppose if they did start capping it I could just downgrade again. *Thinks about it*
