How long is a piece of stringso its available for developers, when is it likely to appear for the rest of us then?
Would I be right in thinking to get those nice icons on your top bar you need to be rooted?
was doing in on win7 pro 32bit for my error
Got the same error too when I tried it in 32 bit. Just repeated the process a few times then it suddenly worked.
There always someone with an smart answerTwice as long as half its length.
ok, ive just flashed my orange one with a stock rom, its working fine wifi and allquestion is it came up straight away with a OTA update 1.15.405.4 should i accept it or is that likely to brick my phone?
Rooted my Orange Desire last night (22nd) with a stock(ish) ROM and this afternoon an update (1.21.405.2) appeared for me - however when the phone attempts to install it the update fails and the phone reboots - I'd guess you'd have the same problem. I'm probably just going to wait another couple of weeks and get a stock 2.2 ROM instead of fussing with it![]()
PAYS Sparta 1.2 ROM
The best ROM i have found, Keep going back to it.
Has anyone put these screen protectors on ?
Don't want to find out it ruins the screen when i take it off.
Seriously, why is my phone always syncing??
The 1.21.405 update .... it was reported (earlier in this thread even) that flashing this on a previous Orange branded phone (i.e. your situation) causes loss of Wifi, as in it won't turn on .... I had this issue with mine in the same situation as you. Supposedly if you have a gold card in the phone then it will flash without the wifi issue but may well lock the phone requiring the purchase of an unlock code to even use your Orange SIM. I have not tried again (after reverting back to the previous release) and am awaiting 2.2 before I do any further fiddling.
The rooting and the "ish" are more likely to have caused that failure.
Which clock app is this?![]()
C:\Users\Lordlukman\Desktop\r6-desire-root>step1-windows.bat
Desire Root Step 1
Erasing cache and rebooting in RUU mode...
erasing 'cache'... OKAY
... OKAY
About to start flash...
< waiting for device >
sending 'zip' (137446 KB)... OKAY
writing 'zip'... INFOadopting the signature contained in this image...
INFOsignature checking...
INFOzip header checking...
INFOzip info parsing...
INFOchecking model ID...
INFOchecking custom ID...
INFOchecking main version...
INFOstart image[hboot] unzipping for pre-update check...
INFOstart image[hboot] flushing...
INFO[RUU]WP,hboot,0
INFO[RUU]WP,hboot,100
INFOstart image[radio] unzipping for pre-update...
INFOstart image[radio] flushing...
INFO[RUU]WP,radio,0
INFO[RUU]WP,radio,6
INFO[RUU]WP,radio,14
INFO[RUU]WP,radio,19
INFO[RUU]WP,radio,27
INFO[RUU]WP,radio,36
INFO[RUU]WP,radio,44
INFO[RUU]WP,radio,51
INFO[RUU]WP,radio,59
INFO[RUU]WP,radio,100
FAILED (remote: 90 hboot pre-update! please flush image again immediately)
sending 'zip' (137446 KB)... FAILED (command write failed (No such file or direc
tory))
Rebooting to bootloader...
rebooting into bootloader... OKAY
Step 1 complete - now use the bootloader menu to enter recovery mode.
To do this, press the power button, wait a few seconds, then use the volume keys
and power button to select the RECOVERY option.
