In-Hand Signal Issue Isolated to Bottom Left Corner
http://www.youtube.com/watch?v=03PQyWp0mWE
Earlier this evening, iPhone 4 signal drops had been reported from individuals holding their new iPhones in their hand. The issue seems to have been isolated to a specific location on the device itself. It is demonstrated well in this video by Insanely Great Mac.
The video shows that calls were consistently dropped when the iPhone 4 was held in the left hand while touching the bottom left corner.
It's not clear if the bottom-left sensitivity is a problem with every iPhone 4 or if there is only a batch of iPhone 4s that are affected. Of course, the solution for now would be to avoid holding the iPhone in the manner demonstrated.
Note: the lower number of bars on the iPhone 4 as compared to the 3GS is a known software issue. Apple told Mossberg that it would be addressed in a future software update.
Sauce:
http://www.macrumors.com/2010/06/24/iphone-4-in-hand-signal-issue-isolated-to-bottom-left-corner/
