*** The Official HTC Desire (Bravo) Thread! ***
There's no way "round" it because it's not supposed to work like that because your source image is way out of size to begin with.
You need 960x800 minimum.
The crop box is to crop out of native res images to the correct resolution.
Why that res? I thought the screen was only 480 x 800?
Okay ran it again and it completed this time but now I'm stuck at this bit:
then select the option to 'Apply sdcard:update.zip'
It cannot find the file so just aborts the installation.
You need to put the zip file in the ROOT of your SD card (not in any folders)
It would have helped if any of the guides state to put the update.zip on your SD card! Presumed that the first process would copy it there as there was no mention of needing to put this file on your card. Fingers crossed I'm rooted now. Best way of knowing? Thanks for your help.
I know it's completely unreasonable to expect a custom rom within 24 hours of the source code being dropped but my fingers are getting sore from drumming on the desk.
Loving the phone so far, miles better than my iPhone I had before this!
Looking around the settings for email and I can't find anything regarding push for gmail, is it already set for push automatically? and does push work with the htc email application?
Under Settings > Accounts and Sync > [Your Googlemail Address]
If Sync Google Mail is ticked then push is enabled :)
soemthing really odd on mine since i flashed to generic htc rom, in android market im searching for logmein ignition and it finds nothing, on my brothers desire which is orange firmware it finds it straight away?
Hmm, odd.
I'm connecting my phone to the PC and its stopped asking me what I want it to do (charge, diskdrive, etc). Although it's ticked as "ask me" and a removable drive appears in windows if I click on it, it says "please insert a removable device......."
Any ideas?
Hmm, odd.
Any ideas?
Try another USB port? (I had a similar thing connecting my Desire to my Mac the other day and changing the port on the system it was plugged into got the phone to ask)
