New pc isnt working!
Ok will go with a fresh install then!!
Guys what board should i get:
MSI 785GTM-E45-785g chipset with ddr2 ram
MSI 760GM-E51-760g chipset and ddr3 ram
Are those the only options? What is your budget?
If you are buying a new motherboard I STRONGLY suggest you buy a new one - as the warranty is so important. Motherboards have an alarming tendency to break during their lifetimes.
Oh ok thanks stulid looks like the second one it is.....
Andi well in my price range of around 50.....I can get 2nd one brand new off a competitor for £40
So go for the second yeh?
Guys i have just bought a new motherboard and i am about to take off the cpu and cooler from my old now....I can get cooler off and cpu out...Am i fine to just put straight into new motherboard and whack the old cooler on or do i need to reapply thermal paste? as i dont have any and was just wondering if it was needed
Get the PSU, and short the green and a black pin of the motherboard connector with something like a paperclip (loads of vids on youtube). Do the PSU fans spin up? If so grab a multimeter and check the voltages. This should rule out the PSU from the possible faulty components.
I would certainly suggest reapplying thermal paste - there is a pretty good chance of air bubbles and bad thermal contact if you just used the same stuff again.
If you don't have any thermal paste, this is the stuff I would suggest going for. Also, getting some of this stuff is very useful as it allows you to easily remove old thermal paste and prepare the surfaces for a new application. Both of these will last you dozens of PC builds and is great for not only CPUs, but I also use it when reseating GPU coolers.
Ok thanks Andi....I am not really looking to spend that much really :p but i guess if its my only option unless of course i can get the motherboard out of the case it is in so i can transfer it :/
Ok guys i have finally been able to get the motherboard out.....Can i just stick this on my wooden table for now? just so i can get the other case ready
Ok guys I have now built my pc and its all good except when I plug my headphones into the front panel they don't work but they work when I plug them into the green one in the back both my headphones and speakers work....do I need to enable the front panel or anything like that?? both the usb on the front panel work.
