Done the little finger tips, quite had as the "pad" as I said is wider than the finger part
then drill everything 2mm or 1.7mm if its going to be taped to M2 thread. Each joint has a screw both sides except the ones with the hydraulic pipe fitting, so all screws had to be cut down accordingly.
then there was a big spark! and he's got me aaaaaaaaaghghhhhhhhh
..... it gets worse, he dives for the knife!
PUT THE KNIFE DOWN! it'll be ok. I manage to persude him to give up and let me trial fit to the shoulder.
Ok back to work, no where near finished yet im afraid, each finger section thats each one, needs a little protective cap. These are so small and fiddly I will have to use styrene, made a start on one.
