Aedus, you're not ordering products directly from their site are you?
What do you mean?
I ordered the wrist straps yeah, and will probably order from them again.
To be honest I dont actually know, and it seems wrong to protect the hands without protecting the fingers. I've just been told that wrapping your fingers is more of a Thai thing and boxing gyms don't like it very much
What do you mean?
he's probably hinting at them being overpriced for what they are, same as golds gym, both overpriced brands
Sounds more like a form problem than anything wraps can deal with.
Are you getting some proper instruction? Even if you don't want to compete I'd reccomend getting someone who knows their stuff to critique your form, else you could end up doing yourself some serious damage.
.Adding wrist curls and reverse curls into your weightlifting routine to try and strengthen the wrists would probably help ( I had a similar problem when I first started boxing coming from weightlifting a few years ago and this helped a lot)
I'm not sure where you've bin training Shroomz, but I've bin trained at a few boxing gyms, as well as kickboxing and MMA orientated sessions and they've all advocated handwraps. Most gyms over here tend to tape up the hands in more of a thai style for fights anyway, it's the best way as it protects all the bones in the hand from the most angles, it just takes too long to do at the start of every session.
Also, it sounds stupid, but you mentioned you've done some weight training before, so I'll ask; are your gloves big enough? I used to get similar pains when using a pair of 10oz bag gloves that were way too small, decided to upgrade to a pair of 16oz gloves for bagwork and sparring and never had any trouble since.
).  What is the best way to confirm if a set of gloves fit correctly.  What should I look out for.  As mentioned, my aches now tend to be more at the base of my thumb / pad under the thumb base and top of the wrist behind where the thumb joins the hand.  i will have a chat with a doctor today to see if I can get referred for an x-ray to see if there is anything that can be done about the pain when bending the wrists back (i.e. doing normal pushups).Psycho Sonny said:why would you need to wrap your fingers?
you wrap your knuckles and your wrists, thats the only parts that need support/protection.
Thanks for this Josh.
Yeah, this is a concern, especially as the person doing the training is a personal trainer at the gym rather than a dedicated boxing / kick boxing instructor. Added to that fact that a good boxer / kick boxer does not necessary make a good trainer and there could be some serious gaps. He does critique form, crosses coming around more like hooks than straight through but if he does the wraps, they tend to be done differently each time and sometimes differently for each hand. The response to me making a note of the discomfort is that 'it will go away as you get used to it'. My confidence is not so high.
Maybe I need to find someone who can provide a few 1-2-1 sessions to check form and make sure I am on the right track but I am not sure where to go to find a decent trainer who does 1-2-1. I will have a look around.
RB
In that case I think you should join a good boxing/kickboxing or thai boxing club that has private lessons, it's pretty normal to be able to hire one of the trainers for private sessions extra cost.
Wraps should feel like a good pair of climbing shoes, tight but not uncomfortable and certainly not painful!
).  What about boxing gloves ?What do you mean?
What i meant is they're overpriced via the website, elsewhere such as Creatine Store sells them at reasonable prices [supplements]. Phd Nutrition is a good company as well and you get a lot more for your money in the long run.
I use Maximuscle, but buying from their website is like throwing my money away tbh.
I got my punch bag put up in the garage at the weekend. My hands seem to be ok with a few sessions without gloves.
Anyone recommend some light gloves just in case I get a few too many breaks of the skin in the next few sessions?
Thanks
You definitely want some gloves, if your hands are ok after a few sessions you aint hitting hard enough![]()
.You definitely want some gloves, if your hands are ok after a few sessions you aint hitting hard enough![]()
12oz Twins gloves. Proper leather and not too expensive really. I would not buy anything other than a good brand for the important stuff like gloves, shorts etc.
4 knuckles, 2 on each hand that are my main contact points heal then get shredded the next time I hit the bags.
It does not hurt, but it's a pain to keep them clean/free of infection all of the time. Thats with wraps and gloves.
Rimblock - Not done a weigh in update for a bit as it's been pretty on and off, but I weighed in this morning at 115, that represents 10kilos since being here. Would not be able to do it without the high intensity of the boxing stuff.
And what's this 10 years ago excuse? Some people out here at 48 training, one of the UK ladies here is 40 and on her 18th fight![]()
