How did people update the media profiles xml file?
There's a zip file in the djdroid thread with it in, edit it in a text editor and then push it back to the system/etc/ folder.
I'm torn between sense and launcherpro!!! I like some of the sense stuff, just wish the launcher for it was better!!
I'll ask again though, I'm running sparta 1.3 with uvoc kernel, did anyone figure out how to stop the sync logo from permanently being in the status bar?
Just replicate the XML file for the recorder settings and re-push the file to the phone, somebody on XDA did it, tried it myself and the framerates are much better.
Confused as to what froyo Rom I should get... OD1.6 or the dj one with old apps2sd....
Anyone wanna help ?
Are you using the modded version or the original djdroid btw?
Just boot into recovery, wipe, flash the ROM, reboot and skip first setup steps and boot into recovery again (holding volume down + power) then wipe and then choose the option to flash zip from SD which is the radio update zip file (doesn't matter about name).
If you want to use Apps2SD then just flash the Apps2SD zip file at this point too I guess!
Make sure all files are on the root of your SDCard too.
Still confusedLike I say, I've always used ROM Manager, can I just use this to install the ROM? I've started up in recovery mode but not sure how to wipe, is it Clear Storage? Don't want to select this if its going to wipe my SD!!!
Thread title was changedStill on the first page!
