Omnius is all you need![]()
Generic UK has only been updated to R2BA020
Has this phone been rooted or did you use the SEUS method to change firmware?
At the lock screen press "menu > back > back > menu > back > menu > menu > back"
Service Info > Model Info. What does it say there?
Onmius works differently from SEUS, as it uses SIN files rather then SEUS dumps.
If you have updated to Generic NCB firmware, then all you will get in the future is NCB updates.![]()
2 sodding weeks.
colours are a 1.6 limitation for sure. confirmed. is the brightness brighter even when x10 brightness is set to full ? the auto brightness setting never seems to get that bright
weird that you can see pixels though. have other galaxy owners mentioned this ?
Just bought an X10 and it should be arriving tomorrow. Can't wait![]()
What type of protection are people using, InvisibleSHIELD? Pouches? Silicon cases? Mixture?
ones youve installed yourself ? or the ones that SE/google installed ?
