*** The Official HTC Desire (Bravo) Thread! ***
I use it for froyo, to over clock and to enable me to connect a wiimote.
Have you tried launcher pro and the cm6 theme as it looks and functions far better than sense.
Just about to flash it as we speak :)
Question - I dont quite get the thought behind UVOC Kernel's... Every time I wanted to OC my PC, I would have to up the Vcore, not decrease it yet, going by the description, they are undervolting AND overclocking :confused:
Hope thats true!
Question: Is there a direct comparison anywhere of Sence vs normal android GUI?
Ive been tempted to try it, but i dont want to lose all my fancy screens that took me a good few hours to perfect! lol.
Use rom manager to backup your current setup so you don't lose anything.
Khaaan, do you find that snesoid doesn't save your game? And the track pad is broken in defrost.
Ah I useNESoid and Gensoid, no problems at all!
optical pad works fine for me.
ROM Manager does not support EXT4 so I would advice using unrevoked and the permanent flash method (which is better anyway!)
Worse battery life today in ages.. only 10 hours with light use.. considering selling at this rate :/
Going back to Sense I think... For me, it is just simpler to use and easier to setup to the way I like it. I cant see anything that I use or want to do with my Desire that stock Android does any better than Sense :confused:
I am, however, using Launcher Pro :)
Anyone have the R4 file uploaded elsewhere as the RS link is not working now as its not a premium account :(
Going to give a stock android OS another go... OD2.0 or DeFrost... what do you recommend ??
R5:
http://robbiekhan.co.uk/root/android/recovery-RA-desire-v1.7.0.1-R5.img
Also, AVERT YOUR EYES!
From here: http://www.neowin.net/forum/topic/893008-htc-desire/page__pid__592898818__st__440&#entry592898818
Personally I think the guy must have had his phone in some moisture ridden environment even if it was unknowingly done - I've had my phone in the bath and so on (music, youtube etc) and never had a problem.
unrevoked 3 is out, do note that once it flashes recovery and boots into recovery the unrevoked flasher will say comms was terminated unexpectedly.
If this does happen to you, your phone is bricked.
Just kidding, it's just a weird message and phone boots into the new R5 just fine :p
Did someone edit my post to remove the Neowin thread link and pic of the bent Desire??
