- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
I find the brightness of the window behind really distracting in 2 and 3 but otherwise very nice. As said 15 is excellent, I'd be more than happy to have had shots like that from the photgrapher on my wedding day.
Is the corner darkness in some of the shots intentional as in a feature of that lens or did you add it PP.
I will try to explain.
The brightness for photo 2 and 3. Why is it so bright, the reasons are 2 fold. First, technical, the light is coming from the window. Back lit, the light in the room is not switched on, it is 11am after all. In real life it actually was not that bright in the room, the sun is not actually shining directly into the room. So, to get enough light into MY side of the subject, i had to expose it more. The result is blowing out the window. That is not a problem here because the window has clutter, apart from the mirror on it, there were other objects, and not to mention the garden and trees outside. I wanted the sisters doing make up as the main source of focus, which is the artistic reason for blowing it out. If i had not, and follow the camera's own metering, i would end up with a half silluette, which is crap.
The vignetting in the photos, they are mostly intentional, some are not when shot on the 16-35 at 16mm with a uv filter on i get a bit of vignetting. I add it in for artistic reasons. Mainly because there normally nothing of interest in the corners, and this draws the eye towards the middle.
They all charge around the same as you too. Other cheesy shots include the bride hiding behind a tree and the groom looking for her *shudders*
