- 27 Mar 2004
- Between Realities
same goes for x264_Benchmark_HD
easyrider said its crap because it doesn't use 100% of the cpu
100% of the CPU only shows optimum speed. Aslong as across the test all settings are the same, and the software is the same. Then the results can be used to compare, whatever the CPU usage.
... taken from the last x264 bench mark
