Does it have DVI? I recently switched from VGA to HDMI on my monitor and the difference was superb.
Yes indeed it does, but the reason I'm still using the same VGA cable from my Core is because my previous PC monitor only had VGA. VGA still looks pretty good on it, on a 19 inch widescreen TFT monitor with a native resolution of 1440x900, but I have to run it on 1280x1024 as that doesn't leave black bars at the top and bottom. I dunno whether it's worth upgrading from VGA to DVI though.
Defo give it a try. On my monitor the difference was massive. Could see people across the other side of the maps on BC2 even though they were just a couple of pixels.
So you bought a new 360s, and have now returned it?
Got mine today at 4:30pm finally after waiting all day! The power brick is definitely smaller but makes more noise than the console itself. The console feels lighter but it doesn't really look smaller.
Is anyone running it on a PC monitor using a VGA cable by the way? I'm using a VGA cable that I bought years ago to use with my Core model, which I imagine should be ok? The PC monitor doesn't have a HDMI or scart socket on it, hence the VGA cable.
Another new design/spec - this one in matt black.
The sleek, new Xbox 360 4GB console features a sleek new design, and includes built-in Wi-Fi N, 4GB of internal flash memory, touch-sensitive buttons and a matt black finish
New Xbox 360 features:
- 4GB internal flash memory
- Wi fi built in
- Matt black colour
- Ready for kinect (no requirement for additional power supply)
- Touch sensitive buttons
Are you using a single cable that is 360-to-DVI-D on the monitor? Or are you using a 360-to-VGA cable, and then attaching a VGA-DVI-D adaptor on the end? Because in that case, I think I may have one of them VGA-DVD-D adaptors lying around somewhere...
£149.99 released 20th August.
Can't see if you can add HDD, but surely you can.
I read somewhere that you can use the original xbox hard drives with the new xbox if you take them out of the outer casing and plug it into the new xbox as it uses a standard sata interface. Apparantly it works fine...
MOOGLEYS said:That looks a lot nicer than the shiny black dust magnet..
