Got this lot - Wife said, "As I have no bump, enjoy your self"
additions to the stiffee.
- Focus Variado Expert Compact 2010
White 58 / XL £599.99
http://www.wiggle.co.uk/p/cycle/7/Focus_Variado_Expert_Compact_2010/5360045297/
Time to train for my next MTB race, hopfully with a few road miles I should be able to do well.... I live in hope.
Guys, can anyone point me in the direction of a 12mm bolt thru axle please?
Im getting the Hope Pro II 12mm bolt thru hub with a wheel.
I have a 12mm conversion kit that includes an axle, but I think this axle is JUST for a conversion and not suitable for the 12mm bolt thru ????
The conversion kits are just for the hub to make the whole a different size, the skewer is specific to your fork. What fork do you have? I think that is what you are saying its not overly clear.
Sorry, should have mentioned.It's for a Rear hub. Not frontSorry, should have mentioned.
135mm. Frame is an Intense SS2.
I'm a bit confudled as to how the 12mm bolt thru axle (Hope) actually keeps the wheel attached to the frame. The ends of the axle are not threaded for bolts.....![]()
I thought you didn't like milk?Very nice frame!
Very nice frame! Do you mean this thing I think they just make the hub hole big enough to take a 12mm bolt through which secures the wheel on.
ThanksVery nice frame! Do you mean this thing I think they just make the hub hole big enough to take a 12mm bolt through which secures the wheel on.
How does the BOLT ON system work?Because it's a bolt through system and not bolt on. 2 bolts thread into the axle at either end....I think.
The Hope hub is internally threaded. So you have your new 12mm axle that goes through the frame (not underneath like on QR) and the 2 screws either end go into the axel and hold the wheel in place on the frame.
Other 12mm through bolt systems may just have a solid piece of 12mm steel that has a bolt at one end and a nut at the other.
QR and 12mm bolt through are both Through bolt designs.
A through axle is an axle system that comes with the frame and not the hub.
Bolt on is just 2 nuts or whatever that secure the axle in place. This can be used for 9/10/12mm systems. 9mm and 10mm being QR. 12mm being like on the Hope Hub you have.
I think that's right.![]()
Im in the market for a new stem, around 70mm but with 25.4mm clamp, thomson is out of the question as i cant afford that, any opinions?
