the VM modem has nothing to do with the wifi rangeSo I can't use my £150 netgear router which I just bought
I bet the VM modem doesn't have good wifi range
i'm using a netgear router which is working fine.
doesn't work on my supplied router.The supplied router is good enough when flashed with DD-WRT firmware.
doesn't work on my supplied router.![]()
Yep, VM have no restrictions on the router you can use. Out of interest what Netgear model is it?
WNR2000, i guess V1What model you got?
Netgear WNDR3700
WNR2000, i guess V1
but the DD-WRT firmware doesn't workAh, you've got a Netgear router. You want to look at the DGTeam firmware.
what is DGTeam firmware?
I might convert to belkin soon as I heard good things about Belkin Double N+ Dual Band
Noise margin is pretty high, it's possible you're on a stability profile which is why your sync isn't that great.
But yeah, with a 41db attenuation you should see around 9~10mb on LLU.
Ahh I seeAh sorry, what I mean is your current provider may have put you on a stability profile due to line issues which is why your sync rate isn't as high as you would expect it to be.
If you were to change providers to Be/O2 or one of the other good LLU services, then you'd expect to see around 9/10mb. Basically the BT checker isn't that accurate as we all knew anyway![]()
