Post Your Home Cine & HiFi Kit...
Hi there no its a 15" (soon to be bigger because its to small) LCD screen :P.
The PC running it is all so connected to the 32" LCD on wall.
My better half likes it as it all so runs as a photo frame etc etc.
just a quick shot...didn't really do much tidying up. Have just replaced my wdtv with a acer revo and whacked the excellent and beautiful xbmc on it. Took a bit of setting up, but starting to get to grips with it!
My bedroom setup
Onkyo 308
Q acousics 1030i
Toshiba Regza 32 720p
Toshiba bdx2000
Xbox 360 60GB
Dvds/Blu-Rays etc
First set up, chuffed to bits with it. Need to sort the cables out.
Plan on gettings some 1010i and 1000c got to sort the room out to get a small couch in first. :)
Samuel, where did you get that wooden stand from that has your DVD player and stuff on. It's size looks ideal for my room.
Quite a bit changed since last time i posted...got all this stuff on a super tight budget.
Sky+, ps3 60gb, xbox 20gb running through a sony str-dg510...speakers are an aego m 2.1 setup wallmounted behind, and using TV speakers for front.
Pany 37" plasma :)
I have this unit
resulting in
Lian Li HTPC with Bluray/HDDVD and DVB-S, PS3, Sony Dav-DZ260 Surround Sound System, sky+ and Toshiba Regza 37XV635DB 1080p TV/Monitor
Redid it all last month.
