What did you do now?![]()
Looks like my pending has settled (somewhat).......
Pending credit: 751,129.39
I've had the same problem as Toxic since Wednesday
so guess it'll be for the long term until the ghost units etc are sorted
but area, it doesn't really matter if the dateline has been passed- I go overdue sometimes on some tasks, and all you get is a message that you should consider aborting task as you might not get credit for it.
<cc_config>
<options>
<use_all_gpus>1</use_all_gpus>
</options>
</cc_config>
I dunno might be wrong and this is an .xml file that I am creating right?
Nice Tiffy Toxic
Right I want my GTX260 to do some Seti work too , Now I have seen what you need to add into the directory but my 260 is still idle the git
<cc_config>
<options>
</options>
</cc_config>
That look rightI dunno might be wrong and this is an .xml file that I am creating right?
Cheers![]()
HELP
On one PC BOINC manager just will not connect, it has a lot of work on it but nothing is visable in manager.
I'm sure someone had this problem before but I dont remember the fix, anyone ?
HELP
Those options look correct, file should be called cc_config.xml, should be plain text (so don't use a real xml editor). File should be saved in the boinc folder and you will need to restart the service. Are the GPU's detected ok? GPUs found are listed near the top of the messages file after service start.
All working now, Sweet, Full steam ahead
I know it's normally at 60-70% so might be OK
NVIDIA GPU 0: GeForce GTX 470 (driver version 25896, CUDA version 3010, compute capability 2.0, 1248MB, 726 GFLOPS peak)
NVIDIA GPU 1: GeForce GTX 260 (driver version 25896, CUDA version 3010, compute capability 1.3, 880MB, 582 GFLOPS peak)
I guess (looking at the GFLOPS) you have not oc'd the 470?
I'd hope not as my 460's are at 788![]()
However, come Monday/Tuesday you will no longer do so. I may not be able to real you in as you so easily did with me, but you ain't gonna get any further away from me.
