What is the highest fluoride toothpaste available?
It goes a little deeper than alergies, it's a neurotoxin....
Again what is the research and what's it's validation. Links means nothing and is usually means it is statistical analysis and nothing else.
So you going to avoid iodine and every other chemical. They are all poisons.
merely shows some people might be allergic to it.
Which is good enough reason no to routinely add it to food, especially without proper labeling.
The National Research Council's scientific review into the EPA's fluoridation program as part of it's safe water standard should be considered.
http://www.fluoridealert.org/health/epa/nrc/excerpts.html
It found that the flouridation of water supplies can lead to adverse health problems in some people.
There is the Precautionary principle set forth in the Journal of Evidence Based Dental Practice in 2006 which stated:
# There are other ways of delivering fluoride besides the water supply;
# Fluoride does not need to be swallowed to prevent tooth decay;
# Tooth decay has dropped at the same rate in countries with, and without, water fluoridation;
# People are now receiving fluoride from many other sources besides the water supply;
# Studies indicate fluoride’s potential to cause a wide range of adverse, systemic effects;
# Since fluoridation affects so many people, “one might accept a lower level of proof before taking preventive actions.
But all these things set aside, the main reason I am against adding fluoride to water when it has no effect on the improved safety of Tap Water (unlike Chorine for example) for consumption is that I cannot choose another Tap-Water if I choose not to access the (questionable) medical benefits of fluoridated tap-water.
Also when there is any question at all over the adverse effects of flouride in the water then it should not be instituted until more research is done.
IIRC it is labelled as containing MSG as are nuts. Shall we ban nuts in food?
Again
I'm not arguing either way on that, I have already said I would like to see new reports done to determine effectiveness.
I am merely arguing stupid statements like it's a poison, well yeah most things are.
Look - I can't be bothered to argue with you about it or sit here providing links for you.
You're obviously not thinking about this logically or you wouldn't be throwing up iodine as an argument for ingesting toxic, un-natural chemicals that have no place in the human body when iodine is necessary for the normal functioning of the human body.
Your time would be better spent finding out how to ingest more iodine than arguing the good and bad of ingesting fluoride and MSG.
I've done enough research myself in the past which has made it clear to me that both MSG and Fluoride are to be avoided. Iodine is a different story altogether and it's unlikely you are getting enough.
If you wish to continue to ingest these toxins then so be it. I hope they do not cause you any health problems in the future.
It is natural as is MSG which is contained in high dosage in certain sea-weeds.
sums it up nicely, even talks about the rat experiment linked a few posts up.
Is MSG bad for you?
The potential ill-effects caused by MSG were first described in a medical journal as ‘Chinese Restaurant Syndrome'. Symptoms including numbness and palpitations were reported shortly after visiting a Chinese restaurant. Such claims have never been specifically linked to MSG however, and could be due to common allergies to ingredients like peanuts and shellfish.
MSG has been linked to many conditions including migraines, asthma, depression and Alzheimer's, but has never been isolated as a cause. Huge amounts of MSG have been fed to humans without causing ill-effects, and MSG is considered a safe additive by every government which tests these things.
Feeding excess glutamate to rats has caused some problems, including retinal damage, but only after feeding them massive amounts of MSG, much more than would ever be consumed by a human.
An ‘international team of experts' met in early 2007 to review the current knowledge of MSG safety, and concluded that MSG was ‘harmless for the whole population' (Consensus Meeting on monosodium glutamate, published in the European Journal of Clinical Nutrition). They agreed that there was no new evidence (since their last meeting in 1997) that certain individuals reacted badly to MSG.
Glutamate is an important chemical in the brain, and there is the potential for neurological effects if very high levels of glutamate reached the brain. However, the ‘blood-brain' barrier effectively prevents this, and problems in rats have only occurred if massive amounts of MSG are given. The group did comment that people with some illnesses have a compromised blood-brain barrier, and the effect of this on brain glutamate levels is unknown.
All the evidence suggests that consuming normal amounts of added glutamate cause no ill-effects. However, it is possible that certain people could be particularly sensitive to glutamate, and if problems are linked to MSG-containing foods they may want to cut their intake of these foods.
IIRC it is labelled as containing MSG as is nuts. Shall we ban nuts in food?
Again
I am not arguing for it being banned, only that you asked for scientific studies as to it's adverse effects and I supplied some.
It is not always the case that MSG is labelled, especially in restaurants.
I agree though that CT and some of the ranting about poisons is simply stupid.
MSG is not the same thing that naturally occurrs in seaweed. Glutamic acid is the naturally occurring amino acid you are referring to.
MSG is Free-glutamic acid, a processed un-natural excito neuro-toxin.
In a factory, however, the bound glutamic acid in certain foods (corn, molasses, wheat) is broken down or made "free" by various processes (hydrolyzed, autolyzed, modified or fermented with strong chemicals, bacteria, or enzymes) and refined to a white crystal that resembles sugar. This substance is known as monosodium glutamate or MSG.
read above post, you have to look at what the research actually shows.
Well that only shows what a panels opinon is on the research rather than what it actually shows.
The link between excessive MSG intake and Obesity is reason enough to enforce food labelling so that people can make that choice themselves.
Plenty of things considered safe are not if taken to excess, so all I am supporting is clear food labelling, and not only for MSG.
Something we can agree on.
Indeed. I simply don't agree with adding anything unneccessarily, be it Fluoride to water or MSG to food.
It shows what the research shows, extremely high levels in rats can alter the brain, the research can't show any thing else as that's all the research tested for.
You have been reading too much from Dr Russell Blaylock MD. His research is not accepted by concensus among his peers.
This is also the same Doctor who said the H1N1 vaccine was more dangerous than the Swine Flu itself, and that Sucralose and Aspartame are toxic and cause Multiple Sclerosis.
Having said that Glutamates are known excitotoxins and can cause neurological damage in some people, those with compromised blood-brain barriers, but there is no reliable statisitcal evidence to suggest that MSG, which is a naturally occuring salt of the amino acid Glutamic Acid is inherently dangerous to the vast majority of people.
I support food labelling of MSG, as it is a non-essential amino acid additive and because some may be more sensitive than others or be compromised in some way to the adverse effects of glutamates as an excitotoxin.
But it is not an un-natural poison as you are suggesting. You are simply mis-informed.
The research was on People, not Rats:
http://download.journals.elsevierhealth.com/pdfs/journals/0091-6749/PIIS0091674997800085.pdf
Conclusions: Oral challenge with MSG reproduced symptoms in alleged sensitive persons. The mechanism of the reaction remains unknown, but symptom characteristics do not support an IgE-mediated mechanism. According to Food and Drug Administration recommendations, the symptoms, originally called the Chinese restaurant syndrome, are better referred to as the MSG symptom complex.
The research found a link between MSG and certain symptoms refered to Chinese Restaurant Syndrome, one strong enough that that the FDA changed the designation to MSG Syndrome Complex.
http://www.medicineonline.com/articles/M/2/MSG-Symptom-Complex/Chinese-Restaurant-Syndrome.html
This is reason enough to make sure that MSG is clearly labelled on all foods however sourced.
The research found a link between MSG and certain symtoms refered to chinese restaurant syndrome, one stong enough that that the FDA changed the designation to MSG Syndrome Complex.
d.
I was referring to the other one about brain cell reactions, which was done on rats.
As I said it merely shows a minor allergic reaction, which has never been life threatening unlike, nuts/latex ect. Minor allergens are not included in the allergy box as people can and are allergic to everything and anything. It is only allergens with a high risk that are included.
MSG is a food enhancer and has to be included on the label. Either as it's name or E621.
Restaurants/takeaways are different as they do not have to label ingredients.
Something that kills brain cells and is usually the product of a manufacturing process I would term as an un-natural poison. But horses for courses, if you want to call it a natural flavor enhancer, spices, yeast extract or whatever then be my guest. I'll be avoiding it either way.
http://en.wikipedia.org/wiki/Excitotoxicity
The toxicity of glutamate was then observed by D. R. Lucas and J. P. Newhouse in 1957, when the feeding of monosodium glutamate to newborn mice destroyed the neurons in the inner layers of the retina.[7] Later, in 1969, John Olney discovered the phenomenon was not restricted to the retina, but occurred throughout the brain, and coined the term excitotoxicity. He also assessed that cell death was restricted to postsynaptic neurons, that glutamate agonists were as neurotoxic as their efficiency to activate glutamate receptors, and that glutamate antagonists could stop the neurotoxicity.
But it does belie the assertion that MSG is harmless, it would entirely be subjective to what you describe as harmful.
An allergic reaction is that a reaction, it is harmless. Unless you can show anyone that has gone into anaphylactic shock.
It is not going to kill you or have any long term effects, in normal consumption quantities. Again unless there is any research that I have not read, certainly nothing in this thread suggest otherwise.
Anything can be a poison in high enough quantities and anything can produce an allergic reaction.
Something that kills brain cells I would term as poison. But horses for courses, if you want to call it a natural flavor enhancer, spices, yeast extract or whatever then be my guest. I'll be avoiding it either way.
Good luck with avoiding all glutamates in food. I would assume you eat a protein free diet and avoid all types of wheat product, dairy products, and so on through about 80% of all food groups. You do realise that glutamates are present in all living cells?
Not much fun considering 95% of all dietary glutamates including MSG are metabolised by intestinal cells in a first pass, and thus getting nowhere near the brain in the first place.
