Is this why I find I'm capped at 50 fps in COH?
How do you set this up then?
Been having a good play now and in game i notice no difference with the card overclocked or at stock....
Why have some people got i7s that will do 4.0ghz at 1.25 volts and then others need 1.35 volts?
Why does one of my cards do 880mhz out of the box and the other 850mhz?
Erm guys sorry if this is a stupid question, i am on my 4th glass of wine now after having been playing Mafia for a couple of hours. I just went into Afterburner while i was having a cig break and for some reason i decided to play with the voltage slider (don't ask lol). Now here's the thing, i have read that the max voltage for these cards is 1.087v, but my slider goes all the way up to 1.213v
Is this normal? I don't want to hit apply in case i just insta-nuke the VRM's. I am assuming that if 1.087v was the max, then the slider would stop there, or that would simply be the value at the end of the slider.
i tried ocing my card earlier and i went from 715> 800 fine
i tried 810 but got a bsod as soon as i hit apply so that means i hit the oc limit for my card without a voltage tweak?
When i push mine to far the driver just re-sets.. Not seen a bsod...?
Try giving it 1v i can get 880/1769/2200 on just 1v.. Temp max,s at 80.c and the fan is a bit noisy but stable..
WHat is weird is if i increase the voltage a bit more and go to 900 my temps actually come down...
try running occt for gpu errors see if it lasts 10 mins on 1.000mv
im thinking not. but happy to be surprised.
Runs fine on occt 900/1800/2200 @1v
@925/1850/2200 1v the driver re-sets after about 10 seconds.
Can you clock it any higher with 1.087v?
