Well arguments aside they both look nice after a clean, ilegal plate spotted on the Porsche though![]()
Heh, thanks.
What is illegal about the plate on the Porsche, though?
Heh, thanks.
[TW]Fox;17253595 said:I think he is referring to the UK bit, but thats actually not illegal. Might be missing a BSAU 145d marking as well.
Clean behind your turret rim, filthy urchin.
I'm a fan of AutoGlym products, and some of the kits/combo bags they do are quite good.
I use AG Body Shampoo & Conditioner to wash with (smells like bubblegum too!), AG High Resin Polish & AG High Definition Wax - just those 3 for a standard wash.
The AG Fast Glass spray works very well, finished with AG Glass Polish and for the trim I use AG Vinyl & Rubber spray. Took quite a few attempts to get the trim on the Micra back to black but the results were fantastic. Unfortunately I haven't a clue when it comes to interior cleaning products.
I'm by no means an expert/detailer but I enjoy putting the effort in. I'm sure you'll get some better recommendations from the more learned folk!
Hey guys
After 12 months of complete negligence, the Commodore is in a pretty bad state and I really need to do something about it. I've been doing some reading in this thread and on Detailing World about how to go about this and now have a good idea on what needs doing. The only problem I have now is that I don't actually own any car care products whatsoever so need to purchase the lot. Does the following list look suitable and comprehensive?
Washing
Meguiar's Lambswool Wash Mitt
Meguiar's Hyper Wash
Microfibre Waffle Weave 60 x 90 Drying Towel
Claying
Meguiar's Quik Clay Detailing System
Polishing
Meguiar's Even Coat Applicators Twin Pack
Autoglym Super Resin Polish
Microfibre Polishing Towel 40 x 60
Waxing
Meguiar's #26 Mirror Glaze Hi-Tech Yellow
If anyone has any suggestions on alternative products that may be more suitable for a similar price I'm all ears. Cheers.
Better off with AG Bumper Care for restoring black trim, itll feed the plastic and last longer.
Why Megs 26 Wax? It's decent enough, but not very durable and you can certainly do better for the money. Megs 16 for example is a better choice generally. Otherwise, everything else is fine. Where are you buying from?
Russ.
