More 6870 Benchmarks...
26 Jan 2009
Looks fake looking at the text, min fps an max fps an score is in bold but min an max aren't looks like someone has cut an pasted over top in slightly different font.
18 Aug 2006
ChCh, NZ
As long as you're a stable and temps are OK the go as high as you can.
Fails with anything past 975. A shame really. If I had the need for it, I'd get a 480 but cannot justify the price over such a small increase in FPS. Not when the 5870 already destroys any other game out there.
6 Oct 2007
North West
If yours is a reference 5870 then you could max out volts safely as they have over volt protection, considering you already have a tasty overclock with no extra volts you should try some extra juice to hit 1000+ core. It's perfectly safe, I had 1000 core @ 1.25 volts on my 5870.
6 Oct 2007
North West
MSIafterburner, if your card is not reference it may not have the necessary hardware to control volts through software. To enable volt control in afterburner hits setting and check the " unlock voltage control " box.
