Oh I see... I didn't even see your location! Sorry...
Finish Kare 1000P is pretty bullet proof, but perhaps isn't the best 'looks' wise.
Are you after durability or best in terms of finish? Can you get Zaino or Clearkote over there?
Here's my silver Megane after Zaino Z2:
Most suggest you can't get good results from Silver, and that everything looks the same. Generally, sealants look better, as they are more reflective. However, some glazes such as Clearkote's add a nice wetness, which when topped with a suitable wax, gives good results too:
CK Glaze then Zymol Glasur:
A deeper, glossier look...
