A full format in Windows 7 will zero-fill the drive, and then that data is *gone*. Irretrievably, irrevocably, absolutely.Read that formatting isnt 100%, so was unsure of that.
You can use one of the utilities which overwrite multiple times with random data if you're truly paranoid, but it's not necessary and really just a waste of time.
dban
/thread
dban
/thread
ah, that's different (sorry) - unlike Win7 and Vista, XP's full format *doesn't* zero-fill the drive, so you need to look at a third-party utility. There's plenty of apps which do this, such as Eraser as mentioned above, or the free version of Active Killdisk.Ahh right...well ive jsut left it on a older XP machine to do a full format, so will leave it at that...thanks!
IIRC the free version of Killdisk only give you the option of a single-pass overwrite, but since it's all you need anyway it should do you fine.Yes sorry, my new machine is busy with me trying to get stuff back onto it so was leaving the much older Xp machine to get on with this.
I take it a Single Pass overite is one of teh options in those programmes.
Never had to do this before...feel like a right numpty., free version of killdisk should do it.
