Richard dawkins
People who think he is as bad as the fundamentalist need to take a step back and think before they utter such nonsense.
He may employ a similar up front in your face method of preaching, but his message is not so blindfolded/brainwashed and is there for you to choose not be forced into.
All he every says is that people should choose, research, test, and prove before assuming or believing.
I think its comically idiotic to not follow as similar system in your own life.
a lot of people say that but I don't see it! If god appeared tomorrow or some other unquestionable proof, then he has said himself, he would convert to that! That's the difference!
If only he used the same critical caution when considering what the scientific method is...
He says that to save face more than anything, because in his mind it's a situation that will never happen.
I was about to post the same thing as there is no way prove/disprove the existence of God, even if you are confronted by an entity claiming to be him.
Hate big brother! Worst thing ever on tv!
Well I'm a lawyer so don't claim to be mr science but his writing makes it easy for me to understand without a scientific background, for that alone he should be commended!
The thing is, he's not actually that popular with many scientists because of the way he (mis)uses science. There are several branches of philosophy around science and what it means that have no bearing on whether it is 'right' or not that Dawkins completely ignores.
Fine, and like hes says himself. Its better to believe with a blank slate and build apon it with information at hand than to create fictious characters and refuse to change them when proved wrong.
If you think like that then there is a chocolate teapot floating around the sun.
Prove me wrong.
With good reason.
We live in a world where people spend billions on fakes like pyschic readings, astrology, homeopathy, instead of feeding the poor and helping the needy.
I for one think he has the right to take that stance as it will only benefit even if he is only 95% correct according to the righteous. Some times people need to stand up and shout.
He is a fantastic evolutionary biologist, truely brilliant within his field.
The trouble is, he tries to use reputation outside of this field when he moves into philosophy, where he has proven over and over that he knows pretty much bugger all.
I've not found many if your posts I agree with, but this one is spot on.
OPINIONS M***********! DO YOU GET THEM?
Prove me wrong.
Prove that it isn't there.
The correct scientific stance on anything that hasn't been or can't be tested is that the result is unknown, or irrelevant, not that it's false. Anything else is an expression of faith in the a priori assumptions of the scientific method being applied incorrectly.
Prove me wrong.
Uh, chocolate melts at less than 40 degrees celcius, the sun is a little tiny bit hotter than that. Therefore, a chocolate teapot cannot be floating around the sun.
That enough proof?
That enough proof?
For this particular chocolate teapot, God has set up a cooling system. Prove me otherwise.
Edit: Sorry, this sounds sarcastic, it's actually a serious (if bizarre) point.
That enough proof?
Exactly now employ that to the things he tells you about religion and all the other things on his show, and the only thing you have left is faith.
That is the point. Take the things you have learnt from science and employ it with reasoning.
Opinons are one thing, the way the things he is trying to remove from our lifes like religious schools and wars based apon scribblings from 2000yrs ago are not opinions.
True, and I agree, but it isnt his method to claim false and if i said that then im sorry. It is his method to work in such as way from a blank slate, using the information avaliable to create a picture of a world based on the scientific method. My point was that its not a good idea to try and prove imaginary things when there is no information to believe in them in the first place. The chocolate teapot signifies the mentality of someone who is creating things they cannot prove just because they know you dont have the information available to prove otherwise.
