It has finally arrived, the big brother to the popular N460GTX Cyclone edition, called the N460GTX Hawk. Some images below:
So what are the main differences?
A new 7+1 phase power design, using the top components for power phases on a GPU. In short this is designed to give a stable and high power delivery to the GPU when required, perfect for getting the ultimate overclock.
3 Voltage adjustments with MSI Afterburner OC tool!
World first card to support voltage adjustment of GPU, Memory and PLL Voltages for greatest overclocking control and results.
V-Check points!
Points on the PCB for multimeter connection for accurate real time voltage readings.
Twin Frozr II Thermals!
Dual 8cm fans with quad heatpipe. Copper base plate with Nickel-plating for ultimate thermal transfer. Results in low noise, and efficient cooling.
As you can see this is the card for overclockers, its quite possible to break the 1GHz Core speed barrier with this card, and is the best way to get the full OC potential out of the nvidia 460GTX GPU. If overclocking is not your bag, on your not quite so bothered about pushing the card to the limits then the cyclone is possibly a better option (it will continue to be sold).
Whats more, the first batch of stock overclockers have comes with Assassins Creed 2 game bundle free
http://www.overclockers.co.uk/showproduct.php?prodid=GX-099-MS&groupid=701&catid=56&subcat=1830
Any Q's or comments on the card as always are welcome.
V-Check points!
