Bet you're chuffed with the improvement.
Would using a filtered face plate make any difference compared to filters (if the sort with a short cable that filter hangs from)? As it reduces amount of joints along cable connecting router.
on any bt nte (main socket) or extensions you dont need the bell wire any more, just have the 2 wires to 2 & 5 on the socket and to the frontplate (for extensions), always have the router into the master socket if possible, a lot of extensions are either cheapo argos specials or old as the hills and can cause a lot of loss with bband speed
glad you have had a major boost![]()
Whats the Netgear Router connection stats page reporting since you added I-Plate?
Your speed test is about right, accounting for overheads etc.
Very niceYou reckon you'd be able to post the full router stats for us, should be in Maintenance -> Diagnostics -> Display detailed ADSL driver informations -> Display
Haha! You think that's awful?! Think yourself lucky!! This is my BROADBAND speeds since my neighbour had his landline installed the other day.
I also live in the sticks like you and used to get about 80kb/s to 120kb/s on a good day. I'm struggling to do anything on the net at the moment - i've even resorted to turning images over 100x100px off when browsing the majority of the time to try and make it bareable.![]()
