Caporegime
- 18 Sep 2009
- Dormanstown.
So you are perfect to push the hawk over 1GHz no problemsYou can make the pudding!!
I'm confused lol.
It wasn't a hard feat to take 5850/5870's to 1GHZ core.
I'm buying a 480gtx - the value one on the 17th when i get paid and i wondered if maybe 2 of these would significantly outperform the 480 or not.
The GeForce GTX 460 SLI configuration absolutely obliterates the GeForce GTX 480’s performance scores, landing a 26% performance coup de grace upon its big brother after continuously battering it with wins in every benchmark at every setting.
Hi
Having bought one of these cards (delivery this morning hopefully).
A couple of questions for MSI-guru
Considering long term stability and the operating life of this card in general...
What would you personally consider a safe voltage to put through these cards and what sort of MHz should I be aiming for, for long term reliability???
I'm not that interested in just being able to boast that I've got the fastest HAWK, I just want a reasonable OC that is not going to knacker the card after a couple of weeks / months use.
My other question is... with MSI actually appearing to encourage people to OC these days (with the inclusion of Afterburner). What's the warranty position if you damage your card using a utility you have provided the end user?
Obviously running a graphics card with a high OC looks great to start with, but will it last the test of time (IE. 2 years down the road). Little point in doing this if your card is FUBAR after a couple of months.
While I know there are many variables here (heat being one of them), are the components in this card REALLY up to the stress long term??? I rather hope so, considering the price difference between this and a stock card.
Thanks in advance.
Understood I'll find out for you..They've actually reduced the maximum voltage down to 1.087v this time.
Stock voltage is 0.975v. +200mV would be 1.175v.
People with the Palit card are able to use Afterburner 1.6.1 to to set them up to 1.213v.
1.087v is not enough to go over 900 Mhz for most of these cards.
MSI-guru
Thanks for your reply. Nice to see a company taking a sensible attitude and one that obviously has belief in their product.
Mines just arrived. Initial impressions are of a very well built card. I'll install it later today and have a play around with it and post my experiences etc. in a separate thread.
What can it do when limited to less than 1.1v? As both the 58xx and GF104's use the same process and a similar ammount of transistors, they should (within reason) overclock to similar levels give equal ammounts of voltage and cooling.Not to blow my own trumpet MSI Guru, but my launch day 5870 ran a 1.1GHZ Core on air, stable.
My current Asus V2 is 1GHZ MSI Kombustor stable.
My old Asus 5850 at 1.087v was 950 stable.
Ok, the reason you cant get the card above 1.087v is due to a hardware limitation with the nvidia card design. The presumably is to prevent damage to the card.
However, on the Hawk series due to the up spec on the components, MSI employ a hardware modification to allow 3 voltage points to be changed independently allowing the higher clocks to be reached.
In regards to the palit, they too suffer the drop down to 1.087v (from the NV driver). If you have seen it go above this, it will be due to a hardware mod on the board. If you have any examples you can check that this is the case.
Hope it helps, but sorry its not better news![]()
Palit released a new official bios for their GTX 460 that allows them to work at 1.213v.
There are similar modded bioses already available, but I am still hoping for an official bios from MSI that will allow the higher voltage limit to work.
Np. Let me know how you get on. Also if you want to post some unboxing pics in this thread, I will whiz you a free MSI t-shirt![]()
Will do.
I like the nice touch of plastic covers over all the connectors.
The only question that you did not answer earlier. Is why most manufacturers of these cards (IE. 460's) are under clocking the Samsung memory. Which if you GOOGLE the chip ID's, appears to be rated at 1,000MHz, as opposed to the 900 MHz that is being used.
Thanks again.
I will check and keep you posted, it would be a nice no brainer OC to begin with.
Do you have the source for this info? If its a BIOS fix I am sure others will follow.
Bhavy, go onto the Guru3D forums, ask around, they'll likely be able to get you a BIOS .
MSI do release BIOS's there.Modded bioses are already available here:
http://www.xtremesystems.org/forums/showthread.php?t=256653
People who have bought the Palit card from OCUK and updated to the newest official bios to get rid of the whining noise also got 1.213v working using the official bios.
I dont like using non official bioses. I can wait to see if MSI will release one first, Im not in any hurry.
Nice one, please PM me with your address and t-shirt size I will get one off to you
In regards the memory, I will check but it would not surprise me if it indeed uses the faster memory to give better OC headroom, that's what this card is all aboutI will check and keep you posted, it would be a nice no brainer OC to begin with.
