*****Samsung F4 2TB Hard Drives In Stock*****
17 Oct 2002
Stoke
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) @ £84.99 inc VAT
Samsung's F4 EcoGreen is the first drive available to feature 667GB per platter. Samsung’s F4 Series EcoGreen Drive (F4EG) is the ideal high capacity drive for green computing environments. The new eco-friendly hard drive, F4EG is designed to meet demand for high performance devices with lower power consumption. Samsung’s EcoGreen F4 makes it possible to design storage systems with the right balance of high capacity, fast performance and energy conservation. Samsung F4EG has the world’s best areal density at 5400RPM rotation speeds. High density means more bits pass under the head faster, and it improves the drive performance. Samsung employs an advanced data recording technology, which brings the next generation technology into today’s single disk platform, enabling Samsung’s new 5400RPM drives to perform at current 7200RPM drive speeds. The internal SysMark test results confirms that F4EG performs as same as 7200RPM drive speeds, and even 10% faster than other green drives.
- Capacity: 2TB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 5400RPM
- Seek Time: 8.9ms
- Warranty: 3 Years
Only £84.99 inc VAT.
ORDER NOW
You better have a couple of these in stock when I get back from holiday on the 23rd! Good price too.
My current data drives have 2GB left between them and are not backed up. :(
Actually that advertising is false. Samsung are NOT the first to feature 667GB platters in a 2TB drive. WD have been shipping 667GB platters on their 2TB Green drive since late May. The model no. is WD20EARS-00MVWB0. I bought 2 from OCUK recently. Would be interesting to see how the WD compares to the Samsung, and if the higher rpm and extra cache on the WD gives it the edge.
I dunno why but I reluctant to buy Samsung drives, still very happy with my twin seagate 7200.11s
Well if these Samsungs are offering close to Caviar Black performance with a lot less heat and noise, then they could be the way to go assuming they are reliable. I have 2 ordered.
