Why not drop a Pug 306 TD lump in, then screw mod it?
The torxx would most probably just tear the chasis in two
You cannot polish a turd. I'd buy something else.![]()
If you must buy an ECU you will be better off with a piggyback unit something like the emanage ultimate, but its 100% pointless on a 1.4TDCI Fiesta.
Not really as £100 ish to go from 60BHP to 85-90 is quite handy. Not worth doing anything else to it though.
Also worth mentioning to the OP, make sure you're not carrying around any excess weight in the car as well.
Remap the stock ECU as a stop-gap, and get saving/thinking about changing cars.
Jigger, visit the Tdoc Forums. Plenty of people on there have Fiestas that are tuned, remapped & intercooled seems to be the way to go.
It's a shame sometimes that people on this forum can't be a little more helpful at times, hatred for the diesel engine still lives on unfortunately!
Eh. And a motec wont?
Why can't you consider just getting the bigger diesel engine? Whats the point of modifying a car when there is a better version already available, for less than it will cost to modify.
Shh, don't offend the dieselists.
Well realistically I'm not getting a 90BHP car with a warranty for mine plus £500.
With bluefin you can remove the remap whenever you like.
A Motec ECU is not going to plug and play, either.
This thread is full of jokes - neither will ever happen.
What ?
Who's to say the dealer will even spot a remap, why can't you remove it at a later date anyways?
Also whos to say the Motec is plug and play, unless you can buy a male or female ECU plug for the Fiesta odds are you will need to spend several hours cutting and soldering wires up on the OEM loom.
I know all this because i've been down this route before with other cars, last time out i ended up spending £200 for a custom loom from the USA.
