advice on gaming pc build (noob alert)
From the games you listed the spec you are building is simply overkill...
"Titan Exodus" Intel Core i5 760 2.80GHz @ 4.00GHz Quad Core DDR3 System
Add the 5850 Total £802.98 inc VAT you also get OC - Full 12 Month collect and return warranty. ;) You can always at a later date replace the i5 with an i7 if need be.
bull****
the difference is just over £100 mark. for that 100 extra hes getting a
5870 over a 5850 and hes sitting nicely in the i7 region which is a better
place to be than the i5.
i know wer most ppl would rather be sitting.
and then u go onto say he can REPLACE the i5 with an i7 LOL
your taking the **** m8
Calm down jake :)
The coolermaster will not fit a 5870 graphics card as its 11" long lol.
I dont think there is any compatibility issues with that mobo with this RAM..Saves another £10
http://www.overclockers.co.uk/showproduct.php?prodid=MY-090-GL&groupid=701&catid=8&subcat=1389
Also is there a reason for the XFX Graphics card? Get this and save another £10
http://www.overclockers.co.uk/showproduct.php?prodid=GX-002-HS&groupid=701&catid=56&subcat=1502
i know lol jakes going mental :p
that graphics card seems pretty good value as you get 2 games too
is the ram exactly the same i.e. speed and build quality
another 20 quid off the system at this rate i'll have it down to 50 quid and i'll buy 2 lol
lol :) but that was a funny 1 ther.
every guy now! who owns an i5 rig and 5850
would surly trade that in + £100 to get an i7 950 and 5870. surely surely.
@Joe
with that extra £20 willy has saved you. add that ontop of wot the sniper case
costed and that gives you £85 for a new case. make sure it can fit an 11" card
@Joe
is this case no good like jake i just picked it ocs it looked good and has the words cool, master and storm in it lol it has to be good :rolleyes:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-175-CM
what would you recommend for a case
My Lancool K58 JUST about fits my 5870 although it was a struggle.
@ £57 bargain but it doesnt come with fans on the top.
So i would suggest this if your willing to spend £86 on a case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-LN&tool=3
looks cool especially with the blue leds and i dont mind spending that little extra on a case as it will be on show
what about this one (i think i prefer the red)
http://www.overclockers.co.uk/showproduct.php?prodid=CA-176-CM
Good choice of case, will keep your system nice and cool.
Cases are personal preference so if you like that case go for it :D
One last attempt at gettin you onto the Lancools :D
http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-LN&groupid=701&catid=7&subcat=1447
EDIT: Jake beat me to it.
Either way both cases are good. The only reason i prefer the Lancool is i think the HAF looks like a tank lol and that Lancool are owned by the best manufactures of cases...Lian Li. But antec are well known for there cooling
the storm sniper is a decent case and looks nice yer.
but it doesnt have enuff room to fit your 5870.
if you wanna add that £20 saved ontop of the sniper money then
the case willy suggested looks nice aswell and will hold ur card.
edit: that case willy said also comes in red if u want red
haha they do it in red
EDIT: just noticed you both beat me too it i like it though
yea lol that setup is similar :)
Joe is going to come out "slightly" ontop tho because hes waiting
to get the ssd a little later and has got the 5870 in, over a 460
which is far nicer
i think we smoked that other thread
which is far nicer
not yet jake, hes actually bought some bits lol
Right hello again folks,
there has been a change of plan, i've decided against the i7 build and i am going along the i5 route instead (sorry jake) i just couldn't justify spending nearly £1200 on a pc.
anyway i've come up with another list i would like you guys to check out
picture.php
i know there isn't a graphics card there as have no idea which one to get. for those of you who can't be bothered to read the whole thread build is for gaming use but no fps mainly rts and a bit of rpg
if you lot dont mind could someone please "spec me" a GPU
and if there is anything else at all i need that i have missed out for example any cables or extra fans could you please say and i'll do my best to add them
oh i dont plan on oc'ing for a few month so i'm just going to stick with the normal CPU cooler for now
EDIT: i'm planning on ordering this on friday morning
