From the games you listed the spec you are building is simply overkill...
"Titan Exodus" Intel Core i5 760 2.80GHz @ 4.00GHz Quad Core DDR3 System
Add the 5850 Total £802.98 inc VAT you also get OC - Full 12 Month collect and return warranty.You can always at a later date replace the i5 with an i7 if need be.
bull****
the difference is just over £100 mark. for that 100 extra hes getting a
5870 over a 5850 and hes sitting nicely in the i7 region which is a better
place to be than the i5.
i know wer most ppl would rather be sitting.
and then u go onto say he can REPLACE the i5 with an i7 LOL
your taking the **** m8
