It looks like you have to manually align the drive according to what I can see on other forumsDon't know if anyone has actually done it though, but the general consensus according to the specs ("4k with emulation"), is the drive will always reports itself to the OS as 512bytes but internally is a 4k drive. So not sure if there is loss of performance due to this.
My F3's transfer a fair bit of humming through the hot swaps in my case which i find a little annoying. Would be nice to know what the F4's are like vibration wise with them being a lower rpm.
I always wondered if the WD's with the spindle held at both ends also reduced some vibration but heard that the seek noise is fairly loud on them.
Indeed. I had same problem before. While I don't consider the F3's noisy they do cause some unusual case resonance. So far no vibration from F4's amd quieter then the touchless WD's I had.
Anybody using the Samsung SpinPoint F4 EcoGreen 2TB (HD204UI) with WHS (just for storage, ie pool HDD, not system), if so, did you have any problems installing it and does it run ok with the other (512 byte sector) HDD's?
In fact I'm half tempted to offload these drives and get another pair of F4's...Have anyone tried to use these in a Synology NAS?
Sounds great please write when you tried that. I am exited to hear, because these disk have not yet been tested with SynologyGot one coming with a synology NAS tomorrow, wasn't sure whether to put the F4 in my rig but think I will try it in the NAS. Hopefully it will work ok.
