- 6 Feb 2010
No. At stock speed the 3.00GHz Athlon II X4 is much slower than the i3 530 at 4.00GHz for general usage and games, not to mention architecture wise Athlon II is fair bit slower than the i3 dual-core and even the Phenom II. The only benefit would be two extra cores...which I doubt would be too useful for you, considering you are only getting a entry level graphic card, not a pair of mid-range/high-end graphic cards... A i3 530 at 4.00GHz will walk all over the Athlon II Quad in games that use no more than two cores (i.e. WOW, Crysis) especially when it's 1.00GHz higher in clock. If you want to get a Quad, the Phenom II 955BE should be the bare minimum you should get.
Athlon II Quad is usually for people who do video encoding besides just gaming, but can't afford the higher price better quality Quad or Hex.
